Old 8/4/12, 12:15 PM
Humberto Carvajal, HI884's Avatar
Humberto Carvajal, HI884 Humberto Carvajal, HI884 is offline
Default Cement tiles too heavy for roof?
Was doing a Wind Mitigation inspection, we typically are asked to do here in Florida the other day. When I went on the roof, I noticed the roof was "wavy" is the best way to describe it. Gable roof and both sides were wavy. The waves were perpendicular to the trusses. When I came down, I went into the attic to look around and what I saw were several trusses leaning, split, bowing, plywood was uneven where they butted up to each other.
I wanted to share these few pictures. They really don't do it justice as you would need to be there to see it better. The roof was put on in March of 2011. The buyer had recently had a friend of a relative do a "general" inspection. i was called out because that inspector wasn't able to do a Wind Mitigation.
Not being an engineer, I advised the buyer to contact one and get their professional opinion on the situation and probable cause. Anyone here run into this before?
Bert
Cement tiles too heavy for roof?-img_6062-jpg   Cement tiles too heavy for roof?-img_6071-jpg   Cement tiles too heavy for roof?-img_6070-jpg   Cement tiles too heavy for roof?-img_6064-jpg
<div align=left><a href=http://www.afloridainspection.com target=_blank>[SIGPIC]
Humberto Carvajal Jr.
Florida State Property Inspections, LLC
Florida Home Inspector License# HI884
LEED® Accredited Professional
Member USGBC South Florida Chapter
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/4/12, 12:53 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector
Default Re: Cement tiles too heavy for roof?
I'd say that was probably a good call. Picture #1 is really a non-issue, but #2 & #3 look like a "stressed" truss. Pic #4 was probably not caused by the weight, but should be addressed none the less.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/4/12, 1:14 PM
Yes, several trusses appeared as the pictures in 2 and 3. The truss span is 24" OC and the home built in 79. There were clay or cement tiles on it before as this particular city, does not allow shingle tiled roofs ( City of Coral Gables, FL ). Another possibility that came to mind was maybe the damage was caused previously and the repairs just never took place when they re-roofed. In any event, I felt better advising him to seek a professional opinion. This was a short sale property owned by an investor. The buyer thanked me for pointing this out. Possibly saved him some money and who knows what other problems in the future.
Bert
Old 8/4/12, 8:05 PM
Robert Ernst Robert Ernst is offline
I have seem some tile roofs sag a little . But I have seen pictures similar to what your showing here on a house that was re-roofed with tile. The local building officials were notified and they told the people to move out. Concrete roofs can weigh 10 times what an asphalt roof does.
Nevada Inspector of Structures #1730
Nevada Energy Auditor #30
www.homecsi.com
Old 8/4/12, 9:25 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
my take:
Photo 1. Looks like the truss was damaged before or during installation. The lateral displacement of the gangnail was not caused by weight from above, but more likely from impact from the side. I'm guessing this was the topmost truss in a bundle lying flat on the ground and they bumped the butt joint with a load of trusses as they were setting trusses with a crane.
Photos 2&3: Look like a truss bowed to the side rather than sagging from weight. It's hard to tell from the photo.
Photo 4: if a split were to be caused by excessive weight for which the trusses were not designed, the splits would most likely occur at the midpoint between support points instead of at the peak where trusses are prevented from slipping against each other by a gangnail and are well supported by opposing each other. I'd guess this was split when the truss was assembled or damaged by bumping during the truss setting process.
It looks to me like either the crane operator or the truss-setting crew were not very good.
This is just in general. The problem may be excessive weight due to a change in roofing material. Drawing conclusions from photos alone can be tricky.
In looking for overloading of trusses by a change in roof-covering material, I'd be looking for general bowing of the bottom chords and compression cracking of drywall at the outside walls upon which trusses bear. This would be vertical and horizontal cracking, mostly at drywall seams, as opposed to diagonal cracking typically caused by soil movement.
Did homes near this one have lighter roof-covering materials?
Kenton Shepard, CMI Inspector/Instructor
Director of Green Building
Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Old 8/4/12, 10:10 PM
No Kenton. All homes in this area are either flat tiles or barrel tile type. No shingles allowed. I did not see any cracks on the drywall surfaces. What caught my attention was the waviness of the roof when looking from the top. That's what prompted me to take a closer look at the trusses inside the attic.
Old 8/4/12, 10:23 PM
I know it's a bit difficult to tell from this first picture but the ridge tiles were actually wavy on this roof. In the second picture of the roof to wall connection, it almost seems the strap is buckled. It may not be anything more than what you've already explained Kenton, but I felt it would be better to have the buyer consult someone more knowledgable and qualified to make that call.
Bert
Cement tiles too heavy for roof?-img_6009-jpg   Cement tiles too heavy for roof?-img_6068-jpg
Old 8/4/12, 11:10 PM
Bert
I understand Humberto, and quite right. It's best to pass on the liability if you aren't sure what you're looking at, and there's no shame or risk with the agent in doing it unless it's an obvious call, which this doesn't seem to be.
The waviness can be caused by either sagging of the trusses or tiles that are not installed in a straight line, and this looks like poor installation to me. The wavy strap at the outside wall in the 2nd photo is just that; a thin strap that bends where the nails are installed.
No worries, you did right to recommend evaluation by a specialist. None of us knows it all (despite some of us who claim we do!) and it takes time to build skills. This is a business in which nobody ever knows it all.
Old 8/5/12, 11:47 AM
Which is a classic indication of an overloaded truss. Trusses (an engineered system), don't "sag." When a truss is overloaded it will "twist" until the point of failure.
You're confusing "trusses" with "conventional framing."
The internal members of a truss (diagonals) are not "supports." They are active members of the engineered system and will be in compression or tension at any given moment, depending on the imposed load.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/5/12, 7:40 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
And judging from those assumed 24 oz. hammer blows, the truss was split hammering it into position when the temporary lateral bracing was holding it from going where they wanted it.
http://search.yahoo.com/r/_ylt=A0oG7...asp%3faid=1414
Kenton, I agree with Jeff on this one.
And don't know about everyone else, but wouldn't some insulation help in that part of the Country?
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
Old 8/5/12, 9:35 PM
There was insulation Marcel. Cellulose, but definitely could have used some more, there definitely wasn't enough as it was thinning in many places.
Bert
Old 8/6/12, 5:52 PM
Charley L. Bottger's Avatar
I did a inspect on a cement tile roof a couple of months ago and had structural stress problems I called for a sructural engineer and it ended up costing about 8K to repair seller was shocked and a little depressed as they had not had a inspection when purchasing.
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
Okla State License # 130
580-268-3340
Old 8/6/12, 5:59 PM
William E. Siegel William E. Siegel is offline
How thick was that plywood? You have some serious issues there. My first question would be is where is the permit for that roof. If that was shingle there should have been an engineering analysis to switch it over to tiles. I am guessing not permit.
Old 8/7/12, 11:53 AM
The roof was installed just last year and was permitted. I have that information. I was told that the City of Coral Gables doesn't allow Shingled roofs but, this home was annexed into Coral Gables from West Miami I believe. So it is very possible it had a shingle roof prior to this. But, it was permitted and finaled by Coral Gables.
Bert
Old 8/7/12, 12:02 PM
Eric C. Van De Ven, CMI Eric C. Van De Ven, CMI is online now
Bert
I would guess, picture 1 and 4 were from a poorly done repair. You can see the hammer marks on the wood in picture number 4.
The other two could have been caused by excessive heat or the extra weight. What size plywood was used?
History of Rubber Tiles mcyr Miscellaneous Discussion for Inspectors 0 12/4/11 10:51 AM
Using approved methods for PVC runs jtedesco1 Electrical Inspections 11 3/18/08 3:31 PM
Asbestos ceiling tiles scoslett Interior Inspections 30 10/20/07 3:30 PM
