Old 7/24/13, 10:15 AM
Steven Appolloni, hi7859's Avatar
Steven Appolloni, hi7859 Steven Appolloni, hi7859 is offline
Default concrete or clay tile
This may be a dumb question, but I have looked online and even went back to the Nachi roof class. How can you tell the difference between concrete or clay tiles? In my area in south west Florida there are a lot of houses with that redish spanish style curved tile.
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/24/13, 10:34 AM
Derek Grace, 16000090161's Avatar
Derek Grace, 16000090161 Derek Grace, 16000090161 is offline
Clay tiles are typically smoother, they do not fade and they are lighter in weight ,if you ever get to hold both... Certainly not a dumb question...
GoldenEye Home Inspections LLC
http://goldeneyehomeinspections.com/
gracey29@hotmail.com
Select your club and trust your swing
Old 7/24/13, 11:32 AM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
Default Re: concrete or clay tile
Clay tile will usually be terra cotta in color or colored with enamel factory coatings. I don't walk on clay tile at all. Concrete tile will be the standard and usually unfinished or painted with white roof paint.
Old 7/24/13, 12:58 PM
Joe Manners, HI7779's Avatar
Joe Manners, HI7779 Joe Manners, HI7779 is offline
The red Spanish tiles you are referring to are normally clay.
Joe Manners
GI Joe Home Inspections
305-733-7447
Old 7/24/13, 1:14 PM
Dominic DAgostino, CMI HI3957 Dominic DAgostino, CMI HI3957 is offline
Take a trip to a local Big Box store, and look at terra cotta planters or flower pots. Pick them up, touch them, feel their weight, the texture, etc.
Now walk to the outdoor paver section at the same store, and find a concrete paver. Repeat the same tactile exercise and learn the differences.
I suggest you touch and "sense" every type of material you come into contact with during all home inspections...you'll develop a muscle memory for each.
Dom.
Old 7/25/13, 2:55 PM
Great idea Dominic, I think I might just have to make a trip to the hardware store this weekend.
Sarasota Home Inspector
Old 7/28/13, 10:01 AM
Charley L. Bottger's Avatar
Concrete tile does not even come close to looking like clay ya should be able to tell the difference from a airplane
concrete or clay tile-dscf3658-jpg   concrete or clay tile-dscf3701-jpg   concrete or clay tile-dscf3705-jpg   concrete or clay tile-dscf3709-jpg   concrete or clay tile-dscf3702-jpg
http://www.oklahomathermalinfraredimaging.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 7/29/13, 11:46 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is online now
1. The most typical profile for concrete tiles is Interlocking. Most clay tiles are overlapping types. The underlap and coverlap of the interlapping portion are half the thickness of the rest of the tile. Clay is generally too weak to be made this thin.
2. You can see the concrete texture by looking at the butt of the tile.
3. These are concrete tiles made to look like clay ties, but if you look closely, you'll see that they are interlocking "S" tiles. The convex and concave shapes are both part of the same tile.
4. These are clay tiles. They overlap (sometimes called "Pan and Cover") and they reflect light differently, since they're smoother.
5. If you see a roof like this, they're probably clay tiles on a home located in the hail belt.
concrete or clay tile-tile-1-jpg   concrete or clay tile-tile-2-jpg   concrete or clay tile-tile-3-jpg   concrete or clay tile-tile-4-jpg   concrete or clay tile-tile-5-jpg
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Old 7/31/13, 5:23 PM
Ya can tell clay tile from a airplane or the neighbors roof
Kenton glad your out of your shell again
concrete or clay tile-dscf5250-jpg
580-268-3340
Old 7/31/13, 6:27 PM
Darn right I can. Clay roof tile doesn't look anything like an airplane!
Old 7/31/13, 7:16 PM
Just depends on what you have been drinking
580-268-3340
Old 8/29/18, 2:18 PM
Deric Tibbs Deric Tibbs is offline
If you sprayed water on the roof, would clay be slicker than concrete?
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
concrete roof tile over asphalt shingles Scott Schultz Exterior Inspections 1 3/29/07 6:32 AM
