Old 6/1/18, 6:38 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via Yahoo to jcampbell
Default Cut Valleys
Fellow NACHI Inspectors...
What is the consensus on cut valleys in regard wo which roof plane shingle goes on top (and is cut)? If the lower roof, like a dormer, is steeper pitch than the upper main roof. I've read the upper roof goes on top (more water shed) and read the steeper roof goes on top. If the ridge lines are equal, I'd go with the steeper option I get that...
What is everyone's "cut-feeling"?
Thanks
Jeff
In the attached photo, both pitches are the same and while I wrote up the main roof should overlap the lower in the cut valley, I didn't make a huge deal of it and now the seller called the contractor who is PISSED... LOL
Cut Valleys-20180522_132954-jpg
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/1/18, 6:43 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: Cut Valleys
California valley..Fine.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 6/1/18, 7:08 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is offline
The larger or the steeper roof plane gets the cut. If those are the same slope, they did it wrong.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
www.LeadingEdgeInspectionServices.com
Old 6/1/18, 7:17 PM
Brad, that is my understanding as well. (yes same pitch)
which takes precedence Steep vs. Higher? for example if this lower/smaller roof was a steeper pitch?
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 6/1/18, 8:23 PM
The steeper plane gets the cut, even if lower. If that dormer had a steeper slope, then it would be correct. You always want the least amount of water runoff or force against the edge of the cut. It wouldn't matter on a weave or a metal open valley.
Brad K Toye
727-403-5029
Lecsi2@gmail.com
Old 6/1/18, 8:59 PM
Marc A. Goldenberg's Avatar
Marc A. Goldenberg Marc A. Goldenberg is offline
How come you know all this stuff
Mastering Roof Inspections: Asphalt Composition Shingles, Part 23 - InterNACHI
Cut Valleys-screenshot-2018-6-1-mastering-roof-inspections-asphalt-composition-shingles-23-internach-png
http://www.alltropic.com
Awards Committee Member
The InterNACHI Awards Committee is the final
authority of issuance of any award the committee offers.
Old 6/1/18, 9:43 PM
Chuck Evans's Avatar
Larger plane with the greater volume of water overlaps the smaller (per Certainteed). Those are so similar that I wouldn't have commented. Cut line should be 2 inches above the center line so that it's less prone to trapping debris. You could argue that you're correct, but IMO its moot on this roof.
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Old 6/1/18, 10:15 PM
Charley L. Bottger's Avatar
Its fine and dandy to inform your client that the shingles were installed wrong but lets be honest and Realistic here do you really expect the seller to tear off and reinstall????? I see wrong cuts quite frequently and nothing is ever done about them. BTW we call them Texas cuts
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 6/3/18, 9:46 AM
(Chuck Evans) I noted it in the report that I was technically wrong but may not be a problem moving forward. I suggested they keep an eye on it and since the back roof needed to be reroofed anyway, that would be a good time to review it again (i.e. monitor conditions). I told them I don't believe it's worth changing. but since the roofer was called out to fix the deteriorated rear roof, somehow he got wind of this comment and made a fuss. All is good...
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 6/3/18, 9:51 AM
my question was a technical question on what is correct. I am sorry if you misunderstood my question. I did not tell anyone to tear off and reinstall... in fact I told them while technically wrong, it was likely fine, just to keep an eye on it... of course this was the day after we saw this other one... so we were sensitive to the problem.
Cut Valleys-20180523_093940-jpg   Cut Valleys-20180523_094111-jpg
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 6/3/18, 10:39 AM
OKie Doke!
Houston, TX
Old 6/3/18, 2:39 PM
Russell G. Cloyd's Avatar
Russell G. Cloyd Russell G. Cloyd is online now
The cut goes on the side spelled out in the manufacturer's installation instructions.
Russell G. Cloyd
House 2 Home Inspections, LLC
859-739-7858
KY License #166164
Certified Radon Measurement Specialist
Certified IAC2 Mold Inspector
KY Fire Prevention Inspector
www.house2homeinspectionsllc.com
Old 6/7/18, 11:45 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is online now
Yes, that's a California cut valley. You can see the pattern in the shingles that lie parallel with the valley.
On a cut roof it gets cut back on the side with the greatest volume or velocity runoff.
Just like if it's an ugly, crooked cut, if it's cut back on the wrong side, that's a sign to look for other problems on the roof, because you shouldn't call for correction of that small a problem, because they're not going to do it and you'll just create bad feeling.
You could check to see if it's sealed along the cut against cross-wash.
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
