The seller has owned this home about 1 year he purchased it from a Real estate agent who had the new shingles installed and optied to not correct the decking that had no H clips installed and with bathroom exhaust discharging into the attic and you can see the results.
Anyone wanta bet how this is going to end up as I recommend removal of shingles, decking and re-installing decking with H clips:shock:
So just to clarify. If there are no H-clips it doesn’t go in your report unless there are visible defects as a result? I know it might sound like I am quizzing you or something but its something I have run into a lot.
Just to play devils advocate for minute, how does it differ from a bathroom exhaust that terminates in the attic but has not caused any issues at the time of the inspection, or a joist cut beyond limits that seems to be holding up just fine. I’m not trying to argue at all. Just picking the brain of an inspector I respect.
As I stated I don’t write them up unless there is problem as was the case in the pic. IMHO most of this inspecting business is based on common sense. If it don’t look proper it probablly is not proper one just has to look for the reason
So what’s your point?
They had a bathroom vent into the attic and you want to recommend thousands of dollars in correction? Are you out of your mind? Do you undersand that H-clips are an engineers or an architects call?
Baby, you should go back to…
