Old 12/5/17, 4:50 PM
John Safstrom John Safstrom is online now
Default Metal dormer installation?
I have not been able to find any install instructions for this type of half-round metal dormer that was recently replaced. My guess is the unsealed overlapping seams are not correct, since I can reach my hand inside. The 2nd seam had a single rivet in the middle.
Is the water designed to go into the seams on top and drain out the channels on the sides?
Metal dormer installation?-p2220346-jpg   Metal dormer installation?-p2220347-jpg   Metal dormer installation?-p2220349-jpg   Metal dormer installation?-p2220348-jpg
John Safstrom
TREC #10566
Systematic Home Inspections, PLLC
Allen,TX
www.systematichomeinspections.com
john@systematichomeinspections.com
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/5/17, 11:38 PM
Greg P. Murray, TREC 22185 Greg P. Murray, TREC 22185 is online now
Default Re: Metal dormer installation?
My experience with them is that a sheet metal guy comes out and templates then fabricates. What you have looks like very shoddy workmanship that in my opinion will leak into the structure.
Old 12/6/17, 12:54 AM
Randy Mayo, P.E.'s Avatar
Randy Mayo, P.E. Randy Mayo, P.E. is online now
Looks homemade to me.
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 12/6/17, 8:05 AM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
DIY project. I would call that possible wind borne debris. Needs to be called out for replacement.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
www.LeadingEdgeInspectionServices.com
