Old 5/11/18, 6:40 AM
David OKeefe's Avatar
David OKeefe David OKeefe is offline
Default modiified bitumen?
I believe this flat roof surface is modified bitumen but would like to get confirmation. I noted worn surface with fiberglass showing in areas. Am I correct and with the worn areas is this roof at the end of it's lifespan? I did note a dried moisture stain on the ceiling below but the leak may of come from the old shingled roof that has been replaced.
modiified bitumen?-dscn9292-jpg   modiified bitumen?-dscn9294-jpg   modiified bitumen?-dscn9297-jpg   modiified bitumen?-dscn9295-jpg
David
InterNACHI Certified Home Inspector #08051301
NYS Licensed Home Inspector #16000038229
NYS DEC Certified Pest Technician # T4865884
518-505-8305
HouseAbout Home Inspections, LLC
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Connect on LinkedIn
Follow HouseAbout_LinkedIn
Follow me on Twitter
HouseAbout_Instagram
Google+
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/11/18, 10:16 AM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
Default Re: modiified bitumen?
Looks more like built-up roll roofing with a failed coating. Whatever it is, it should have been replaced with the new shingles. A good coating may save it for a few years.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
www.LeadingEdgeInspectionServices.com
Old 5/12/18, 10:23 AM
Dan Bowers, CMI, ACI's Avatar
Dan Bowers, CMI, ACI Dan Bowers, CMI, ACI is online now
You might try something like this
We noted deterioration such as the fibers showing through the low slope roof covering at multiple places. This is often a sign of roofing at or near of its useful lifespan. This condition can lead to moisture intrusion.
We recommend having a licensed and competent roofing contractor read the report; review the roofing system, its accessories and their conditions; and then service, repair, or replace any deficiencies or unreliable conditions as needed to properly correct them. We also recommend that you verify the insurability and acceptability of the roofing with your insurance company prior to closing escrow.
Dan Bowers, CMI
Licensed Contractor / Builder
Certified IAQ2 Mold Inspector
Licensed HVAC Service Technician
EDI Certified Stucco / EIFS Inspector
iNACHI – US Member of the Year 2010
ITC / FLIR - Level I Infrared Thermographer
FHA - 203k Inspector / Compliance Inspector
ICC Code Inspector (Plmbg, Elec, Mech, Bldg)
Old 5/14/18, 11:31 PM
Russell G. Cloyd's Avatar
Russell G. Cloyd Russell G. Cloyd is online now
Looks like missing flashing and exposed roof sheathing in pic 4 of 4. That might be the source of the leak/stain.
Russell G. Cloyd
House 2 Home Inspections, LLC
859-739-7858
KY License #166164
Certified Radon Measurement Specialist
Certified IAC2 Mold Inspector
KY Fire Prevention Inspector
www.house2homeinspectionsllc.com
Old 6/9/18, 12:16 AM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is online now
Looks like someone went after roll roofing with a power washer.
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
