This appears to be a sort of foil radiant barrier in the attic of a 1949 house. 90% of it has crumbled and fell to the attic floor. My thoughts are that it trapped moisture because there are no vented soffits and no ridge vent, yet moisture levels in the attic were not excessive.
Does anyone know if this stuff is, in fact, a radiant barrier, and if so, is it really a defect since it’s not required, and because most of it is crumbled to the attic floor?
haha…very true, and sounds like my line of thinking, Jeffrey!
I won’t recommend it be re-installed at all, unless they put a ridge vent in to let the hot air escape, and Since the shingles need replacing, it would be a great time to do it.
They sure did it the hard way!
I would probably say something to the effect of, radiant barrier was not installed properly as evidenced by the fact most of it is no longer present!
Old, poorly-installed radiant barrier has failed and should be removed. Replaced at the owner’s discretion. Lack of rafter bay ventilation will void shingle warranty
