Old 11/15/18, 2:01 PM
David Wicker David Wicker is offline
Registered InterNACHI Vendor
Default Removal of Moss from roof
I'm hoping you all can provide me with some safe effective ways to remove moss from a roof. I just had a few large trees removed to stop the growth of the moss and now I would like to remove it.
Any help would be appreciated.
Dave
David J Wicker
Home Inspection & Drone Insurance
315-552-5334
315-877-3930 - Cell
dwicker@chinsurance.cc
http://chhomeinspectorinsurance.com/
" In your corner"
protecting your business and what's important to you.
Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/15/18, 2:26 PM
Roy D. Cooke, Sr's Avatar
Default Re: Removal of Moss from roof
Dave
What did Google tell you .
I think there is much good info there .
Old 11/15/18, 2:46 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
Removal of Moss from roof-moss-lawn-weed-killer-100099153-64_1000-jpg
Long term, is a zinc strip at the ridge which helps to prevent it in the future.
I had the same problem on my back yard shed and I bought a product at HD that had a mix of clorox in it and it killed everything. I waited a week and then used my small pressure washer that only has 1500 PSI and it don't damage the shingles nor remove any of the surface aggregate. Here is the before and after. Not very clear, but it came off and looked like new.
Mind you, the roof shingles were 28 years old.
Removal of Moss from roof-dscn2384-jpg Removal of Moss from roof-dscn2449-jpg
Have a Professional do it if you are worried about damaging the shingles.
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
Old 11/15/18, 9:59 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
Originally Posted by mcyr View Post
Attachment 204436
Attachment 204437 Attachment 204438
UH-OH!! Planter next to the foundation... WRITE IT UP!
Removal of Moss from roof-planter-foundation-png
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Old 11/16/18, 6:22 AM
Actually that was an apple tree I cut down a few weeks before and the stuff I bought had clorox in it, but was not damaging to shrubs.
Old 11/19/18, 8:08 AM
Thank you, The internet has all sorts of ideas so I thought I would go to the experts and sort through the BS. Much appreciated.
Dave
David J Wicker
315-552-5334
315-877-3930 - Cell
" In your corner"
Old 11/19/18, 8:14 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
TSP with bleach works good. Trisodium phosphate.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 11/19/18, 10:01 AM
https://structuretech1.com/zinc-strips-prevent-moss-growth-on-roofs/
Zinc Strips Prevent Moss Growth on Roofs
By ReubenSaltzmanIn Roofs, Zinc Strips On November3, 2011
While black stains on roofs are a cosmetic issue, moss growth is morethan just cosmetic. Not only does moss look terrible on roofs, it willalso shorten the life of the roof covering and possibly lead to roof leaks. Whether you have wood or asphalt shingles, moss can grow on the roof ifit doesnít dry properly.
As with black algae stains, the most common place formoss to grow is on the north side of the roof, but if there are enoughoverhanging trees or other forms of shade, moss can really grow anywhere. If you want to kill the moss, follow the link above that explains how toremove black roof stains; the process is the same for killing moss. Theresults certainly wonít be as immediate, but itís effective. Today, thefocus is on what you can do to prevent moss growth on your roof.
Have you ever noticed that moss and black stains donít appear on roofsunderneath the areas with galvanized metal?
Old 11/22/18, 1:08 PM
Douglas Cossar, CMI. NHI's Avatar
Douglas Cossar, CMI. NHI Douglas Cossar, CMI. NHI is online now
You might want to wait till spring, David
Mighty cold right now
Cheers
Doug Cossar
InterNachi Lifetime Member
National Home Inspector NHICC00503
Retired and living the dream!
Old 11/22/18, 1:18 PM
Cheers
Tomorrow is a good day ( Syracuse, New York )
no wind good sun 38F or 3c
Old 11/22/18, 3:33 PM
That will shiver your timbers
Cheers
Doug Cossar
Old 11/22/18, 4:42 PM
Removal of Moss from roof-winter-sucks-jpg
