Old 1/17/19, 9:16 AM
Stephen D. Whittington Stephen D. Whittington is online now
Default Old roof inside of roof?
Wondering if any of you have seen this before. This is the 2nd one I've seen here in Central Florida where an addition was done on a home, and part of the old roof was visible inside of the attic space of the addition. The connection point of the roof structure seems suspicious, although I couldn't navigate close enough to fully view it. We have engineered trusses here, but conventional framing closer to the connection point to the old roof. I can't see how this would integrated into the existing structure except by attaching right to the old shingles and roof decking, which has to be insufficient. Any thoughts and how would you write this up?
Old roof inside of roof?-20190116_144213-jpg   Old roof inside of roof?-20190116_130324-jpg
Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/17/19, 9:21 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: Old roof inside of roof?
I've seen that quite often..
I wouldn't write anything up about it.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 1/17/19, 10:08 AM
Alan Singer, #16000058241's Avatar
Alan Singer, #16000058241 Alan Singer, #16000058241 is online now
Its done all the time when an addition is added. Better to rip the old off but its not wrong as long as the shingles are not asbestos containing shingles
Sterling Home Inspections
Westchester NY Home Inspections
Fairfield CT Home Inspections
(914) 413-7781
Old 1/17/19, 10:12 AM
Thank you all. Good to know. I guess my bigger concern was how the new roof system was attached to the old. It doesn't seem to be an adequate attachment. Normally I would expect to see a 2x10, 2x8, etc. laid flat on the old surface and then rafters attached. Not sure how I could know if the old shingles contain asbestos. I just don't want to short change my client.
Old 1/17/19, 11:14 AM
Stephen H. Payson's Avatar
Stephen H. Payson Stephen H. Payson is online now
Correct, I would have preferred to see the rafters attached to sleepers as well, but at this point, it wouldn't be worth correcting. It's not going anywhere unless there's a hurricane in which case, sleepers aren't going to help anyway.
Stephen H. Payson
Peak Inspection Services
Office: 908-750-6789
NJ Home Inspection License #24GI00125400
NJ Radon Mesurment Technician License #MET13261
InterNACHI# 13081415
www.peakinspectionservices.com
steve@peakinspectionservices.com
Residential Inspections | Commercial Inspections
Serving all of Northern New Jersey
Residential & Commercial Contractor For More Than 34 Years!
Old 1/17/19, 7:13 PM
Great input. So thankful for this forum and community. Really appreciate it from all. Happy inspecting!
Old 1/17/19, 9:07 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
That's what it is all about here, Stephen...feel free to jump in when you want.
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
~retired~
The above post represents my personal opinion.
Old 1/18/19, 3:48 PM
William B. Ogletree's Avatar
William B. Ogletree William B. Ogletree is online now
I agree with the opinions expressed, but the following thought occurs to me:
It is often not possible to tell whether an addition of this type is properly tied in to the existing structure. In such situations, would it not be prudent to state as much in the inspection report and urge the buyer to attempt to determine whether the addition was done with the necessary permits?
William Bruce Ogletree
Ogletree Inspection Services
214-287-4630
www.ogletreehi.com
ogletreehi@gmail.com
Old 1/21/19, 1:32 PM
Dennis DiVito Dennis DiVito is offline
If you are in FL, what are the requirements for hurricane strapping on roof framing?
Old 1/26/19, 10:06 PM
Ian W. Mayer, CMI's Avatar
Ian W. Mayer, CMI Ian W. Mayer, CMI is online now
All the time.
My last house was the same way.
There are a ton of post-WWII homes in my area that all started as 2 bed 1 bath homes for returning GIs, and over the years, many of them have had additions or several.
Sometimes the original shingles are still on the old roof in the attic.
