Old 7/7/13, 6:49 PM
Mike Pettitt, HI 136 Mike Pettitt, HI 136 is offline
Default Valleys cut wrong; report verbiage
Was wondering if anyone has some report verbiage they could share for when the shingles in a cut valley are cut wrong in refenence to the larger or smaller planes of the roof and also if you recommend correction. Thanks.
Valleys cut wrong; report verbiage-vally-cut-wrong-jpg
Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/7/13, 9:50 PM
Sean Fogarty's Avatar
Default Re: Valleys cut wrong; report verbiage
What exactly is wrong?
Fogarty Inspection Services Group of Palm Bay FL
FL Licensed Home Inspector #8351
Infraspection Level 2 Thermographer #8788
FL Licensed Mold Assessor #MRSA2330
Certified Master Inspector
Home inspections, Commercial Inspections, Mold assessments, Thermal Imaging, Wind Mitigation and Insurance Inspections for Palm Bay, Melbourne, Cocoa, Titusville, Vero Beach and all the surrounding areas.
321-506-5125
fogartyinspectionservices@gmail.com
www.homeinspectorpalmbay.com
Old 7/7/13, 9:57 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
Nothing I can see.
Old 7/7/13, 10:13 PM
Gary D. Rowden Gary D. Rowden is offline
2 different types of shingles (Three-tab shingles and dimensional)
Are you concerned with the transition in the valley, it looks good from here.
The Vent is not properly flashed
Old 7/7/13, 10:21 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
Looks like all dimensional shingles to me and it all looks good.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Old 7/7/13, 10:34 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
OP is referencing the larger roof plane is lapped first and the smaller roof is valley cut...should be the other way around. Don't think this is a major defect but should be noted and checked for sealing under the cut.
Old 7/7/13, 10:35 PM
Jeffrey Moore, AZ#49250 Jeffrey Moore, AZ#49250 is offline
Mike,
You are correct that the cut side should be on the larger surface side so the water flows to the smaller roof field shingles. I have not had that occur here so I don't have verbage
Jeff Moore
www.quantumhomeinspections.com
Flir (ITC) Level II Thermographer
Mesa, AZ
(602)448-2926
Old 7/7/13, 10:36 PM
Upon further review I believe you right Russell, all dimensional shingles
Old 7/7/13, 10:43 PM
No signs of problems, and yes shingles are sealed. Thanks all for your help.
Old 7/10/13, 8:35 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
Here Mike, from the InterNACHI Narratives:
"Valley shingles cut on wrong slope
Properly installed asphalt shingles are not cut down the centerlines of valleys, cutlines should be offset approximately 2 inches toward the side of the roof with the larger square footage to help prevent runoff flowing down the slope from finding it’s way beneath shingles on the adjacent roof slope.
Shingles on this roof were cut on the wrong side of the centerline. This condition may increase the chances of roof leakage.
No leakage beneath valleys on this roof was visible at the time of the inspection."
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Need help selecting report software mmonroe Inspection Hardware, Software & Publications 207 9/25/10 10:34 AM
**HOT** Texas Inspectors use of REI-7A-0 escanlan Legislation, Licensing, Ethics & Legal Issues for Inspectors 27 11/20/07 1:09 AM
Texas Inspectors & March Texas REALTOR Focus Marc Tuno General Inspection Discussion 4 3/23/07 12:39 AM
