Old 12/19/18, 10:49 PM
Stephen D. Whittington Stephen D. Whittington is offline
Default White Stains on roof
This one is in Florida. I see this quite a bit, where I see white staining (or is it a lack of dirt/fungal growth?) on older asphalt roof coverings, immediately under all penetrations. Can anyone tell me what it is from, and if it tells us anything about the roof condition I should be reporting? Thanks in advance for your expertise!
White Stains on roof-20181218_145458_hdr-jpg
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/20/18, 6:55 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: White Stains on roof
Zinc from the lead boots.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 12/20/18, 6:57 AM
Well, that was easy! Thanks much
Old 12/20/18, 8:52 AM
Randy Mayo, P.E.'s Avatar
Randy Mayo, P.E. Randy Mayo, P.E. is online now
Actually, the roof has black algae (Gloeocapsa magma) on it and rain washes the zinc down killing the algae. So the light-colored stain is actually the original shingle color. Copper will also kill the algae. You can actually buy shingles now with copper mixed in with the granules to prevent the algae.
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 12/20/18, 9:52 AM
Chuck Evans's Avatar
It's the rest of the roof that's stained. Those jacks are improperly installed by the way. The flanges should be interleaved with the shingles.
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 12/20/18, 12:13 PM
Don C. Hawley's Avatar
Don C. Hawley Don C. Hawley is offline
FYI, for retrofit on existing roofs there are a number of products from zinc strips to spray on algae killers.
Don Hawley CPI
Hawley Home Inspections LLC
Home Inspection Services, Termite, Radon & Sewer Scope
DonHawley575@gmail.com
Licensed Radon Professional
Licensed Home Inspector
Old 12/21/18, 6:28 AM
Thanks much. What do you mean by the "jacks?" The bottom flange of the lead boots? I see them both interlaced with shingles, and not in the photo I believe.
Old 12/21/18, 6:37 AM
Ah nevermind, I'm just not used to them being called jacks in these parts. I got it now, lol. Too early!
Old 12/21/18, 7:17 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Yep, we call them vent boots in these parts. I hope you read up on black algae and AR shingles vs non-AR shingles.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 12/27/18, 4:35 PM
Thumbs up Re: White Stains on roof
Originally Posted by kshepard View Post
The lower flange should terminate on top of the shingle in the course below. One is correct, the others are wrong.
Thanks Kenton. Yes, that's what I like to see also with that flange hanging out. I see them fully buried under the shingles all the time unfortunately!
