Contractors Forum This forum is hosted by InterNACHI for contractors. Remember: InterNACHI members who are also contractors must take particular care to abide by the InterNACHI Code of Ethics.
Old 3/17/17, 5:20 PM
Gregory Giguere Gregory Giguere is offline
Student Inspector
Default where is the ethical line between contractor and inspector
I am coming out of the contracting world, currently working on getting my license in NH. I do all phases of construction from excavation to roofs to custom cabinetry, I understand that contracting a defect is unethical. But where is the line drawn in terms of bidding on a project. Should I only think about superficial projects (bath or kitchen remodels with no defects present) updating flooring because of aesthetic displeasure? Or completely separate inspection and contracting jobs.
I'm really looking to see what other guys have done starting in inspections. I have little capital to work with, so I was thinking about complimentary construction work I can do until I can establish myself as an inspector, without affecting my future reputation as an inspector.
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/18/17, 2:22 AM
Jeffrey R. Jonas's Avatar
Default Re: where is the ethical line between contractor and inspector
https://www.nachi.org/code_of_ethics.htm
Jeffrey R. Jonas
Owatonna, Minnesota
Old 3/18/17, 2:26 AM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Simple. If you inspect a house, you or any company you have a financial interest in cannot work on the home for 1 year. Period. Very simple. Many licensed states have this rule.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
Old 10/30/17, 11:47 AM
J Dupont J Dupont is offline
As both a builder and an inspector, I use a class code on my contacts.
A client can be either a construction client or an inspection client.
They can never be both, you are either one or the other.
After a year, an inspection client becomes classed as an "expired" inspection client and becomes eligible for construction activities.
It keeps it easy for marketing purposes.
Old 10/30/17, 1:06 PM
Larry W. Morrison, CMI's Avatar
Larry W. Morrison, CMI Larry W. Morrison, CMI is offline
Certified Master Inspector
Several years back I was also an insulation contractor and had to distance myself and take a financial hit because I chose to not do work on or bid homes I inspected. (In my state it would not be illegal, but ethically it would not be correct under my own standards as well as interNACHI's C of E)...
Ultimately you will probably find setting the standard now will help you be known as an inspector that is ethical and honest.
On a Related Note: I also find it a conflict of interest as well as Wrong for a State to require an inspection on your Automobile by the same outfit that is going to "Repair the Problems" THEY found".....(This is actually the reason most states have dropped annual inspections as a requirement for registration. (Utah just dropped starting Jan. 1 2018... It Harms the consumer more than helps.
