I am setting up a new computer and almost have it ready to use.
I have homegauge installed and the settings all transefered. I copied the reports from my homegauge folder on the old computer and copied them to the new one. They are in the data/homegauge/reports folder just as on the old computer.
When I opened HG on the new computer it had defaulted to the user/./. folder. I went into options and advanced folder options and set it to the correct folder. When I click on open and reset database, it shows “no reports”.
I checked and double checked that it is set to the correct folder but HG cannot find the reports.
I keep all my data files in the data folder on the C: drive. That way all the data files are together and easy to access without having to drill into the user folder. That is the way I have set it up for years and it is much better.
Thanks Dom for trying! Robert I am not familiar with moving the folder out of Documents. It sounds like you did it correctly. I am sorry I am no help. Smarter people come in tomorrow at 9
828-254-2030
Actually, I did not move the folder out of documents. I started using a folder named Data to consoildate my data files well befor windows came up with the stupid name “My Documents” and did the same thing I had been doing. I simply kept it that way. I name my “Documents” folder “data”
As to the issue I mentioned here, I discovered the problem. I was directing HG to look at the Reports folder but did not realize that it was looking for a “Reports” folder inside the folder. I redirected HG to the HG folder and it is working.
