Go Back   InterNACHI Inspection Forum > Vendor Forums > HomeGauge
HomeGauge This is a place for HomeGauge customers to discuss HomeGauge software and services, and prospective HomeGauge customers to ask questions and get advice about picking home inspection software and services.
Old 1/11/17, 2:18 PM
Philip J. Hudak, CPI Philip J. Hudak, CPI is offline
Default IN? NI? Both?
Had an inspection this morning where the furnace was in the garage, but I couldn't get to it as the owner had some boxes and furniture stacked in front of it. Then a Porsche Boxster against all of that.
So, I mark 3.0 Heating Equipment as NI, and make the appropriate comment with pic regarding inspection restriction.
My conundrum is when I get to 3.3 Distribution Systems. I was able to inspect most of what this entails, except for the furnace fan and air filter. Normally, this is the section where I kindly explain where the filter is, the size, when and how to change it, etc. Can't do it in this case, of course.
So, how to mark 3.3? The best that I can come up with is that I should mark both IN and NI, and make the inspection restriction comment again as in 3.0. I definitely want this noticed.
I also think that I should force at least 3.0 to show up in the Summary to make sure that it is not overlooked.
How would you deal with this?
Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/11/17, 4:49 PM
Dominic DAgostino, HI3957 Dominic DAgostino, HI3957 is offline
Default Re: IN? NI? Both?
Don't let the software dictate your reporting methodology.
I use HG, and have changed the template to account for various real world data entry.
List what you can and can't inspect, and why you couldn't inspect those areas. Given the fact that you didn't or couldn't inspect the furnace, I imagine someone will be looking at it before the option period expires; have the distribution system checked at that time.
Dom.
Dominic D'Agostino
Home Pride Inspection Services, Inc.
Longwood, FL 32750
407-260-1533
Old 1/12/17, 5:01 PM
Thanks, Dominic. You are right.
I recently started using HomeGauge, and knew that I would at some point heavily modify the template when I wasn't so busy.
But, it's costing me more time to adapt to the template as-is than I want.
Guess what I've been doing all day. Thanks for your input and push.
Old 1/14/17, 7:24 PM
Dan Bowers, CMI, ACI's Avatar
Dan Bowers, CMI, ACI Dan Bowers, CMI, ACI is online now
Certified Master Inspector
Let DISTRIBUTION be ducts, etc
LET the blower, filter, etc be at THE furnace which was NI
Dan Bowers, CMI
Licensed Contractor / Builder
Certified IAQ2 Mold Inspector
Licensed HVAC Service Technician
EDI Certified Stucco / EIFS Inspector
iNACHI – US Member of the Year 2010
ITC / FLIR - Level I Infrared Thermographer
FHA - 203k Inspector / Compliance Inspector
ICC Code Inspector (Plmbg, Elec, Mech, Bldg)
Old 1/14/17, 8:04 PM
David B. Myers, LHI 10779's Avatar
David B. Myers, LHI 10779 David B. Myers, LHI 10779 is online now
Hi Philip,
If you would like, you could send me your email address I'll send you a image of how I have my Heating & Cooling Section setup on my template.
dave@myersinspections.com
Dave Myers
Myers Inspections, LLC
LHI #10779
http://www.myersinspections.com
Old 1/15/17, 2:44 PM
Dan: Yes, I re-wrote the template to include an air filter and fan integral to the furnace, while still having the option to have fans and filters externally down the line in the distribution system (e.g., duct boost fans, filters in return grills). Appreciate your input.
Dave: Email sent...and thank-you. I sent you a screenshot of mine, too.
Old 1/15/17, 3:10 PM
Phil, Just sent you my reply...let me know if I can help!
Dave Myers
LHI #10779
