I have the HIP and HIP mobile. I did an inspection using the default template and it seemed to take me a while to get through all the final touches. I know that speed comes with experience but for a new user I am asking if you have any tips on speeding up the report process. What are your favorite templates? Any tips on good things to modify that have worked for you? I am liking the software so far and the HIP support seems second to none! Thanks for any feedback!
When using a standard template is there a way to not have some of the info appear on the report? i.e. When inspecting an electric water heater I don’t like the look of putting N/A next to gas valve condition. Could I eliminate certain things like that off the report? Or is it common to have a few "N/A"s on a report? thanks
There is a setting to only print what is commented on.
I would never comment on not available gas valve to an electric water heater (granted, I rarely ever see electric water heaters here in Los Angeles). Much like I don’t comment on the non-exist straps on a tankless water heater.
I’ve been using a template that another inspector gave me (which was very helpful), which I modified to my style of inspecting. He is a desktop guy, I wanted to use mobile and have realized that with mobile the template needs to be set up for optimization with mobile. For sure set up your own template ASAP, once you get busy it will only be harder.
Go to Report Settings->Options->Item Options and uncheck “Print items even if no comments are selected” to set HIP to not print items with no comments (or ratings on).
Ian, the default template has changed quite a bit since you first used it years ago. You may want to check it out at some point! There is definitely a lot in it though as it’s easier to delete than hadd. Of course nothing is as good as customizing things to fit you personally though.
