I seem to have an issue with the cover photo while using cover page designer. I have everything lined up when designing the cover page then when I generate the report the picture isn’t in the same location as when I designed it. It usually ends up being higher than I planed and a portion of the picture covers up my logo. This was the same with all versions of 5. Anyone else have this issue?
The cover photo will depend on whether you’re taking your pic in 4:3 or 16:9 and whether you’re in landscape or portrait mode. It’s best to add a cover photo first, then use the designer so you can use it with an actual photo. The designer is just a preview mode and could be off slightly as it’s size is reduced to your monitor. Just make any adjustment as needed to make sure the report looks correct. If you need help just give us a call or send your files to our help desk so we can take a look!
