whats the best template for doing a basic inspection? i’m using inspection pro
Building your own is basically the only way to go. Out of the box the templates are not very good.
Never heard of inspection pro.
Or do you mean Home Inspector Pro?
Robert is correct. Building your own template that matches YOUR inspection technique, YOUR wording, and YOUR skill set will be the best.
The INACHI template might be a good starting point. Like Robert and Stephen said, building your own template is the way to go. Once you get it where you like it, you will change it again. It is a never ending task.
Canadian Template which comes included is a good start .
Hi Jeffrey, like others said, building your own is a great idea.
Kenton’s template is pretty well like by many here… you can find for Home Inspector Pro and Homegauge at http://hinarratives.com/
Best of luck!
