Spectora This is a place for Spectora customers to discuss Spectora software and services, and prospective Spectora customers to ask questions and get advice about picking home inspection software and services.
Old 11/28/18, 11:58 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is online now
Certified Master Inspector
Default Would this comment go under Information, Limitations or Observations?
Localized portions of the asphalt shingle roof had small blisters visible. Blisters are a cosmetic issue and do not cause premature failure of the shingles or affect their performance. They typically appear during the first 5 years after shingle installation, and are often related to inadequate roof structure ventilation.
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/29/18, 1:28 AM
Chuck Evans's Avatar
Certified Master Inspector ®
Default Re: Would this comment go under Information, Limitations or Observations?
I wouldn't report blisters as cosmetic in Houston.
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 11/29/18, 7:25 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Yep! Observations.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 11/29/18, 11:16 AM
Gary D. Rowden Gary D. Rowden is offline
I would say “Observation”
And I would not include as written
Old 11/29/18, 11:34 AM
Guys, this post was a question specifically about how to designate comments in Spectora. Thanks Roy!
To avoid drift, I posted in Roofing inspections about asphalt shingle blisters.
See it here.
Old 11/29/18, 2:59 PM
Joshua L. Frederick Joshua L. Frederick is online now
Definitely observation...other two wouldn't really make sense.
http://northwestohiohomeinspector.com
Defiance home inspector
Northwest Ohio home inspector
Old 11/29/18, 5:39 PM
See it here.
Didn't intend to send the thread adrift. The implication of my comment is that it would be an observation.
From my perspective: I treat these categories as follows:
Limitations are listed to set client expectations as to things that I cannot or elect not to do. It may be due to licensing/qualifications (e.g., engineering... WDO...); access/visibility (e.g., can't see under the slab... there was no access to an attic space...); willingness to inspect (e.g., low voltage wiring, devices, components... Water treatment systems...)
Information is either generic commentary/boilerplate or factual details about the house and systems which are not condition dependent (e.g., It's a wood framed structure on a slab foundation... Heating type, fuel, make, model...)
Observations are pretty much anything that I feel is comment worthy regarding the condition of the house and its components. These may include anything from serious defects and hazards to trivial items which are worth knowing about
Houston, TX
Old 11/29/18, 6:02 PM
Aaah, that’s what I was looking for, thank you Chuck!
Old 12/1/18, 6:15 PM
Mike Hazelwood, CMI's Avatar
Mike Hazelwood, CMI Mike Hazelwood, CMI is offline
As a Spectorian, I would say Observation or in my case "Finding". With in an observation/Finding we can slot it in 3 different categories "Minor", "Moderate" or "Safety / Major". That's how I have my template set up, others may vary.
Hope this helps
Mike Hazelwood
P.O. Box 6494
Bakersfield, California 93386
calpro@calproinspections.com
www.calproinspections.com
Old 12/5/18, 12:07 AM
Hope this helps
Do you mean you can change the template, Mike?
