Spectora This is a place for Spectora customers to discuss Spectora software and services, and prospective Spectora customers to ask questions and get advice about picking home inspection software and services.
Old 1/9/19, 12:57 AM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
Certified Master Inspector
Default List choice or multiple narratives?
Which do you prefer in Spectora; A single narrative in which you choose from a list to complete a narrative (like the one in red), or a series of complete narratives from which you can pick one (blue and black)?
Exterior Stair location: These exterior stairs were located at/near the _____.
Exterior Stairs Stair Location - Front: This set of exterior stairs was located at the front of the home.
Exterior Stairs Stair Location - Rear: This set of exterior stairs was located at the rear of the home.
Exterior Stairs Stair Location - Left side: This set of exterior stairs was located at the left side of the home.
Exterior Stairs Stair Location - Right side: This set of exterior stairs was located at the right side of the home.
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/9/19, 9:41 PM
Default Re: List choice or multiple narratives?
Doesn't anyone have a preference?
Old 1/10/19, 1:18 PM
Joshua L. Frederick Joshua L. Frederick is online now
Not exactly sure what your asking?
http://northwestohiohomeinspector.com
Defiance home inspector
Northwest Ohio home inspector
Old 1/10/19, 1:54 PM
Junior S. Fudge's Avatar
Junior S. Fudge Junior S. Fudge is online now
He's asking if people want fill in the blank type narrative where you can enter the location, etc, manually, or if people would prefer multiple of the same narrative with different locations, etc, already placed in them.
Old 1/10/19, 4:28 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
If I was using Spectora, I would want the red one because there often are more than one exterior set of stairs or whatever. So, I could add to the suggested narrative beginning by reporting ...were located at/near the front right corner and the rear of the house...for example.
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 1/10/19, 7:28 PM
It's a bunch of mumbo jumbo and/or a bad example just to note where the heck exterior stairs are located? lol.
Spectora has location tags - easy peasy.
e.g. Exterior stairs appeared to built by a 3rd grader - safety concern. Have repaired by a blah, blah, blah
Old 1/11/19, 1:07 AM
Thank you Junior.
Iím creating the InterNACHI Narrative Library Template for Spectora.
Old 1/11/19, 1:57 AM
Spectora folks are suggesting I try to reduce the size of the Library, so Iíll be deleting full narratives like the ones in black and blue and using lists where possible.
Old 1/11/19, 2:55 AM
Patrick J. Cloninger, TN 247's Avatar
Patrick J. Cloninger, TN 247 Patrick J. Cloninger, TN 247 is offline
I would second the use of location tags in Spectora when at all possible. It would reduce a lot of redundancy.
Patrick Cloninger, TN License 247
Pinpoint Home Inspections
www.PinpointTN.com
"Inspecting East Tennessee Since 2006"
Old 1/11/19, 2:58 AM
Also, have you considered getting feedback from the Spectors FB user group? You will have a much more eager and responsive group there. Not many use this group on NACHI.
www.PinpointTN.com
Old 1/11/19, 12:09 PM
Mike Hazelwood, CMI's Avatar
Mike Hazelwood, CMI Mike Hazelwood, CMI is offline
I would say the first narrative with out the blank. Spectora has location tags but it does not fill in a blank.
Handrails at one or more flights of stairs were damaged, loose and/or wobbly. This is a safety hazard. Recommend that a qualified person repair as necessary.
As Patrick stated, go to Spectora's User FB group. You'll get a ton of input.
Hope this helps
Mike Hazelwood
P.O. Box 6494
Bakersfield, California 93386
calpro@calproinspections.com
www.calproinspections.com
Old 1/11/19, 12:57 PM
Thank you Junior.
You're welcome Kenton.
Old 1/15/19, 1:40 AM
That has turned out to be good advice, Patrick.
I hadn't realized that you can't link a specific (limited) set of multiple choices to a specific comment. Apparently all the multiple choices appear under the title of "Location" and you have to choose from a big long list of choices, many of which don't apply to the comment you want to use.
Old 1/15/19, 8:28 AM
As I said in post 6.
It really works great in the field. I've got all the ones I use the most towards the top, which makes it really simple. I could show you a screenshot of my location tags if that would help you any?
