InterNACHI Inspection Forum
InterNACHI Inspection Forum (https://www.nachi.org/forum/)
-   General Inspection Discussion (https://www.nachi.org/forum/f11/)
-   -   INachi graphic request thread (https://www.nachi.org/forum/f11/inachi-graphic-request-thread-103542/)
jfrederick 7/29/15 12:06 PM
CSST bushing/grommet graphic as mentioned here: https://www.nachi.org/forum/f2/corrug...rommet-103538/
Also, a water softener improperly tapped into sanitary drain one would be great along with one that shows the proper way to do it (with an air gap, trap, etc.)
A house wrap picture would be swell, as well :D
Thanks in advance.
ddesiga 7/29/15 7:28 PM
Re: INachi graphic request thread
Can this image get an update? It's hard to read. It can be found on the How to Inspect for Moisture Intrusion course. Thank you
http://education.nachi.org/coursemed...4_flashing.jpg
This one too.
http://education.nachi.org/coursemed...5_flashing.jpg
jfrederick 7/29/15 7:31 PM
AC condensate trap graphic also would be nice..
rlewis5 7/29/15 7:39 PM
1 Attachment(s)
Would this work for you? Easy enought!
mclark2 7/29/15 8:42 PM
Quote:
The trap needs a clean-out. Those darn things get full of muck and clog, and it's impossible to get a coat hanger through it! :|.)
jjonas 7/29/15 9:47 PM
1 Attachment(s)
Quote:
The one in Roy's graphic must be restricted... the water level is too low in the trap!
gromicko 7/30/15 12:38 AM
CK is on vacation this week, but when he returns, he'll work on building them.
jfrederick 7/30/15 6:02 AM
Quote:
Appreciate it!
jfrederick 7/30/15 9:11 AM
Some other ideas:
-Gas meter clearance graphic
-Don't vent bath fan to soffit graphic
-Venting bath fan out sidewall (best practice)graphic
Proper crawlspace vapor barrier graphic showing fastened to walls and seam tape
-Proper crawlspace/basement sill insulation (not fiberglass batts)
-Graphic showing why crawlspace/basement sill is a vulnerable area with air transfer
-No tees on horizontal plumbing drain lines graphic
Hundreds more to come :D
jfrederick 7/30/15 10:09 AM
- Proper flex ducting strapping graphic
- Proper flex ducting installation graphic
- Plumbing vent to small/frost closure graphic
- S-trap to P-trap conversion graphic
- Metal column attachments at beam and floor graphic
jfrederick 7/30/15 10:10 AM
CSST bonding graphic
jfrederick 8/3/15 6:44 AM
Meter base J-block for vinyl siding or any J-block graphic(s)
Steel post column top plate dishing graphic
Hose bib pitch graphic
jfrederick 8/3/15 7:38 AM
Footing drain tile graphic
ckrowiak 8/3/15 11:00 AM
I'm on it!
jfrederick 8/4/15 7:47 AM
Rubber roof defects/conditions like ponding, ripples, wrinkles, and "alligatoring"
Window hermetic seal failure/causes graphic
Gas fireplace safety damper clamp graphic
Ceiling fan clearance-to-floor graphic
Copyright © International Association of Certified Home Inspectors
