InterNACHI Inspection Forum
InterNACHI Inspection Forum (https://www.nachi.org/forum/)
-   Plumbing Inspections (https://www.nachi.org/forum/f22/)
-   -   What is this part? Steam Boiler. (https://www.nachi.org/forum/f22/steam-boiler-132238/)
jlebeau2 9/27/18 9:45 AM
2 Attachment(s)
What is this part/cover?
I inspected a 4 unit building and on each of the steam boilers there was rust around this part.
Thanks!
Josh
rlewis5 9/27/18 9:51 AM
Re: What is this part? Steam Boiler.
I'm not sure , but I think it is the inspection hole..manway, manhole..
mlarson 9/27/18 9:56 AM
Quote:
Originally Posted by rlewis5 (Post 1984140)
I'm not sure , but I think it is the inspection hole..manway..
What size are you? ;-)
It's probably access to the heat exchanger tubes in the fire box.
rlewis5 9/27/18 9:57 AM
Large enough to make me happy...:D
asinger 9/27/18 3:04 PM
Looks like the tank-less/domestic hot water coil - not in use. They are a poor design and fail long before the boilers fail. They are found on the low end builders models - saving money on the hot water tank or water heater and paying the most possible for hot water production.
jlebeau2 9/28/18 10:23 AM
Thanks Alan, Barry, nope - didn't think to look at them. I will going forward. Thanks.
lkage 9/28/18 11:08 AM
Quote:
Originally Posted by jlebeau2 (Post 1984782)
... nope - didn't think to look at them. I will going forward. Thanks.
I like honest inspectors/people. You'll go far Joshua! :D
jlebeau2 10/1/18 9:36 PM
Thanks Larry.
I try!
Copyright © International Association of Certified Home Inspectors
