InterNACHI Inspection Forum
InterNACHI Inspection Forum (https://www.nachi.org/forum/)
-   Electrical Inspections (https://www.nachi.org/forum/f19/)
-   -   Grounding not verified (https://www.nachi.org/forum/f19/grounding-verified-133446/)
eklugmann 12/12/18 11:44 PM
2 Attachment(s)
I'm sure this has been addressed before but still unclear what to say. 1969 build, single family. Appears to be an upgraded panel in 2012. I know there should be two grounding methods; I see two grounds exiting the panel, but thats it. Couldn't see any grounding rods. The top bare neutral went into an BX type armored cable. So do I mention that I couldn't see any actual grounds? "Actual grounding method couldn't be verified"?
Thank you
rlewis5 12/13/18 8:20 AM
Re: Grounding not verified
The service main has an earth ground. The termination of the main ground wire for the electrical service was not accessible.
eklugmann 12/13/18 9:14 AM
So clear and simple, thanks!
Robert Meier 12/13/18 10:14 AM
Quote:
Thank you
Some constructive criticism, you should work on your terminology. The conductors in question are Grounding Electrode Conductors (GEC's) not "grounds". The bare conductor in the cable armor is a GEC not a neutral conductor. If there is a metal water pipe that would be a grounding electrode, same for ground rods. Connection to ground rods are not require to be accessible so it's possible that they're buried. :D
eklugmann 12/13/18 2:25 PM
Thank you, you are correct and I appreciate your input.
Copyright © International Association of Certified Home Inspectors
