InterNACHI Inspection Forum
InterNACHI Inspection Forum (https://www.nachi.org/forum/)
-   Interior Inspections (https://www.nachi.org/forum/f18/)
-   -   What type of garage ceiling is this? (https://www.nachi.org/forum/f18/type-garage-ceiling-135020/)
tewald 3/14/19 2:46 PM
3 Attachment(s)
Home built in 1965. There is rebar inside the cemented areas, but they look like some type of concrete blocks. Just curious, first time seeing this.
ddivito 3/14/19 5:58 PM
Re: What type of garage ceiling is this?
What was above this ceiling? It does look like block, but I can not tell
tewald 3/14/19 6:01 PM
2 Attachment(s)
It was a builtup/tarred roof under the rooftop porch
mgratton 3/14/19 10:46 PM
I've seen that type of flooring used at the Boldt castle in NY 1000 Islands during a tour. The castle was built in 1900. Its a concrete block flooring system.
plesieur 3/16/19 5:20 AM
Its a formed and poured slab/ ceiling. You install supports, install decking, tie rebar in a certain pattern, place concrete, finish the surface, remove the forms and supports, install roofing, go home.
Copyright © International Association of Certified Home Inspectors
