InterNACHI Inspection Forum
InterNACHI Inspection Forum (https://www.nachi.org/forum/)
-   Inspecting HVAC Systems (https://www.nachi.org/forum/f20/)
-   -   Condenser unit not level (https://www.nachi.org/forum/f20/condenser-unit-level-5017/)
loconnor 6/4/06 10:46 PM
1 Attachment(s)
Is it a problem if the A/C condenser unit is not level on its pad. Actually the pad is not level. This is a first for me.
mboyett 6/4/06 11:10 PM
Re: Condenser unit not level
Yes, units 8-10 or more out of level should be reported as such. This condition can affect compressor operation, lubrication and places excessive stress on the freon lines and connections. I would definitely recommend an HVAC tech further inspect and repair the one in the photo.
JLilly 6/4/06 11:27 PM
Yes that is too much. For heatpumps I always liked to leave the pad slightly off level to allow for good drainage during the heating season. Otherwise you get a big ice build-up around the bottom when they would defrost.
dandersen 6/4/06 11:30 PM
So how does your car A/C work?
Would you please elaborate this issue in detail?
rray 6/5/06 11:43 AM
It's all in how things are engineered and designed. Car systems are designed for cars, taking into account speed, stops and starts, turns, G-forces, etc. Home systems are designed for homes where such conditions are not expected.
loconnor 6/5/06 1:36 PM
Thank you very much. This will help
Copyright © International Association of Certified Home Inspectors
