Ten Most Common House Problems
Recent surveys by U.S. and Canadian home inspectors resulted in this list of the ten problems most frequently found in the homes they have inspected:
1. Improper Surface Grading/Drainage
This was by far the most frequently found problem, reported by 35.8% of the survey respondents. It is responsible for the most common of household maladies, including water penetration of the basement and crawlspace.
2. Improper Electrical Wiring
A significant number (19.9%) chose this item as the most common home defect, which includes such situations as insufficient electrical service to the house, inadequate overload protection, and amateur and often dangerous wiring connections.
3. Roof Damage
Although reported by only 8.5% of the respondents as the most common problem, roof leakage caused by old or damaged shingles or improper flashing was considered by inspectors to be a frequent problem.
4. Heating Systems
Problems in this category include broken or malfunctioning operation controls, blocked chimneys, and unsafe exhaust disposal.
5. Poor Overall Maintenance
Even the novice home buyer is usually aware of this situation, demonstrated by such signs as cracked, peeling and dirty, painted surfaces, crumbling masonry, makeshift wiring and plumbing, and broken fixtures and appliances.
6. Structurally Related Problems
Many houses, as a result of problems in one or more of the other categories, sustain damage to such structural components as foundation walls, floor joists, rafters, and window and door headers.
7. Plumbing
Though not ranked by the respondents as a Number One problem, plumbing defects still rank high among the house problems encountered, and include the existence of old and incompatible piping materials, as well as faulty fixtures and waste lines.
8. Exteriors
Flaws in a home’s exterior, including windows, doors, and wall surfaces, are responsible for water and air penetration, but rarely have structural significance. Inadequate caulking and/or weatherstripping are the most common culprits.
9. Poor Ventilation
Perhaps due to overly ambitious efforts to save energy, many home owners have over-sealed their homes, resulting in excessive interior moisture. This can cause rotting and premature failure of both structural and non-structural elements.
10. Miscellaneous
This category includes primarily interior components, often cosmetic in nature, which were not found frequently enough to rank individually in our survey.
NOTES:
(a) It is significant that, within this list of ten problem categories, at least four are directly related to the damaging effects of water. It is apparent, therefore, that after a home is built (presumably in a structurally sound manner), keeping water out is the homeowner’s most important and continually challenging objective.
(b) It should be clearly understood that the statistics relating to electrical and plumbing problems, and roofing in particular, will vary greatly, depending on regional climates and building codes, and that this list, therefore, represents an average.
(c) In addition, the age of a home plays a significant role in these findings. In older, urban houses, problems, such as heating system failure, inadequate electrical service and worn plumbing can be found with much greater frequency than reflected in this survey.
(d) Survey response percentages were given only for the first three categories because they were so high and statistically meaningful. Items 4 through 10 were ranked significantly lower than the top three, and vary regionally.
