Above your top floor ceiling sits a blanket that could be costing you hundreds of dollars every year while making your family uncomfortable—your attic floor insulation. This unglamorous layer of material works around the clock to keep your heated and cooled air inside your house, but when it's inadequate, damaged, or improperly installed, it becomes an expensive problem.
Most homeowners have no idea how much insulation they have or whether it's doing its job effectively. That fluffy pink, yellow, or white material spread across your attic floor should form a continuous thermal barrier between your living space and the outdoor temperature extremes above. When this barrier fails, your expensive heated and cooled air escapes into the attic, forcing your HVAC system to work harder and run longer to maintain comfortable temperatures.
The warning signs of insulation problems show up in your comfort and your utility bills. Rooms that are consistently too hot or too cold, despite your thermostat settings, often indicate insulation deficiencies. High energy bills that seem unreasonable for your home's size frequently point to air leakage and inadequate insulation. Ice dams forming on your roof edges in winter are a classic sign that warm air is escaping through insufficient attic air sealing and insulation.
Moisture is insulation's worst enemy. Wet insulation loses most of its insulating value and creates perfect conditions for mold growth. Roof leaks, plumbing leaks, and condensation problems can saturate insulation, making it heavy, ineffective, and potentially hazardous to your family's health. Compressed or matted insulation has also lost its ability to trap air, which is how insulation actually works.
Animals and pests can destroy insulation quickly. Rodents tunnel through insulation, creating air pathways that bypass your thermal barrier. They also contaminate insulation with droppings and urine that create health hazards and odor problems. Birds and bats can scatter and compress insulation while building nests in your attic space.
Air sealing works hand-in-hand with insulation but is often overlooked. Gaps around light fixtures, plumbing penetrations, ductwork, and attic access hatches allow air to move freely between your living space and attic, making even good insulation less effective. These air leaks also carry moisture into the attic, where it can cause condensation problems.
Modern building codes require much more insulation than older homes typically have. A house built 20 or 30 years ago might have half the insulation that current efficiency standards recommend. Air sealing and adding insulation is often one of the most cost-effective home improvements you can make, with energy savings that continue for decades.
Before insulation problems cost you more money in wasted energy, have your attic evaluated by someone who understands thermal performance. A qualified home inspector can assess your current insulation levels and identify areas where improvements would provide the greatest benefit. They can inspect the insulation and provide you with an unbiased assessment of the actual condition of your home.
The International Association of Certified Home Inspectors (InterNACHI®) trains inspectors to evaluate insulation and energy efficiency issues.
For a professional inspection of your insulation and an overall home energy check, including valuable information you need to make smart decisions about your home, contact your local InterNACHI® certified home inspector.
Good insulation isn't just about saving money—it's about creating a comfortable, healthy home that performs efficiently year-round.
Home Project Oversight Done Right
More Home Maintenance Articles
Become a Certified Attic, Insulation, Ventilation, and Interior Inspector
