Built-Up Roofing (BUR) Components
A built-up roofing (BUR) system is a multi-layered roof typically installed on low-slope or flat roofs. The
alternating layers (plies) consist of asphalt and roofing felt, topped with a surface layer of gravel to
protect against UV damage and weathering.
A built-up roofing (BUR) system is a multi-layered roof typically installed on low-slope or flat roofs. The alternating layers (plies) consist of asphalt and roofing felt, topped with a surface layer of gravel to protect against UV damage and weathering.
License
