Most homeowners focus on what's happening inside their house and forget about the biggest threat lurking right outside their front door. The way water moves around your property can make the difference between a dry, healthy home and a nightmare of foundation problems, basement flooding, and structural damage.
Here's the simple truth: water always wins. If your yard doesn't direct water away from your house, that water will find a way to cause problems. It might pool against your foundation, seep into your basement, or saturate the soil until your foundation starts shifting and cracking.
The ground around your home should slope away from the house—at least six inches of drop over the first ten feet. Sounds simple, but you'd be amazed how many homes violate this basic rule. Over time, soil settles, landscaping projects change the natural drainage, and what once worked properly now channels water straight toward your foundation.
Landscaping choices matter more than most people realize. Those beautiful flower beds right against your house? If they're not properly designed, they can create water collection areas. Mulch piled too high can hold moisture against your siding. Even well-intentioned French drains and decorative rock can backfire if they're not installed correctly.
Gutters and downspouts are part of this story too. If downspouts dump water right next to your foundation instead of carrying it well away from the house, you're essentially creating your own flooding problem.
Before you start moving dirt or calling a landscaping contractor, get a professional assessment. A qualified home inspector can evaluate your current drainage situation and help you understand what's working and what isn't. They'll give you unbiased information about potential problems before they become expensive emergencies.
The International Association of Certified Home Inspectors (InterNACHI®) trains home inspectors to identify drainage issues that many homeowners miss.
For a comprehensive check on your home's foundation and advice on managing water around your property, contact your local InterNACHI® certified home inspector.
Smart drainage isn't just about preventing floods—it's about protecting your home's most important structural element.
Home Project Oversight Done Right
More Home Maintenance Articles
