Home Inspector Newsletter #93 May 2016
Subscribe to the newsletter. It's free. Unsubscribe anytime.
LATEST INSPECTION NEWS
More Than 30 Types of Certifications (online & free)
Click here.
To choose from more than 30 types of inspector certifications, do the following two steps:
Step #1: Join InterNACHI.
  • Join InterNACHI as a member at $49 per month (cancel any time) or $499 per year.
Step #2: Get Certified.
  • Members may choose from more than 30 types of inspector certifications (all online & free for members) by visiting www.nachi.org/certification.
How to Become a Certified Home Inspector (1-min. video)
Click here to play video.
Once you become a certified home inspector, you will be awarded the Certified Professional Inspector® designation.
To become a certified home inspector and attain your CPI designation, you must complete all of the requirements:
Certification Requirements:
  1. Join InterNACHI.
  2. Pass InterNACHI's Online Inspector Examination (online, free, and open to everyone).
  3. Complete InterNACHI's online Code of Ethics Course (online and free for members).
  4. Complete InterNACHI's online Residential Standards of Practice Course (online and free for members).
  5. If you have never performed any fee-paid inspections, you must submit four mock inspection reports to InterNACHI's Report Review Committee (free service). If you have already performed any fee-paid inspections you can skip this step.
  6. After joining InterNACHI and completing the above requirements, you must sign your affidavit to become a certified home inspector.
Customized Books
Your inspection company can have its own home maintenance book to give to clients.
Click here.
Get custom home maintenance books at no additional cost! The home maintenance book teaches your clients how their home works, how to maintain it, and how to save energy.
We can put anything you want on the cover, including a photo of:
  • you,
  • your inspectors,
  • your inspection vehicle, or
  • whatever you like.
We'll provide all the design work for free.
You can completely customize the entire front and back cover so that it looks like your book. Give your clients YOUR book!
Free, Live Home Inspection  Class #17 with Ben Gromicko
In this class, we'll learn how to perform a home inspection. We'll review hundreds of inspection images and the inspection report from a recent home inspection performed by the instructor. We'll discuss infrared, branding and marketing, and tools. You can ask questions through a live, online chat.
Everyone who registers for the free class will receive a link to the video recording of the class. So, register now.
Finished Basement Walls
Dry to the Interior?
Finished basement walls are exposed to many different things that come from all directions. The finished basement wall is exposed to different temperatures, moisture levels, water vapor movement, heat, cold, cool concrete, warm interior air, etc.  And they all relate to the biggest concern with basement finished walls: moisture.
Traditional practices, such as the use of a warm-in-winter vapor diffusion retarder on the inside of the finish wall system, have resulted in moisture problems.  A basement foundation wall assembly that dries toward the interior is the best and most desirable.
The insulation to use when finishing a basement is a rigid foam insulation board. That type of insulation will allow the foundation wall assembly to dry inward, away from the foundation wall and toward the interior of the finished basement space.  The foam insulation should be vapor-permeable (greater than 1 perm). The greater the perm, the easier it is for the wall to dry inward.
Because the foam insulation needs to be continuous and sealed at the seams, the insulation should be installed behind the wood-framed wall. Additional insulation can be installed in the spaces between the studs.
Custom Logos for Inspectors
Click here.
InterNACHI's Design Team just created a new custom logo for Mountain View Home Inspections at no cost to the member.
Logo and marketing design services are a free InterNACHI membership benefit.
Customized Video Ad
Going to Highest Bidder!
Tuesday night's auction item being provided by Inspector Outlet is a customized online video ad produced for your inspection company.
  • The auction starts now and ends at 9 p.m. MST on Tuesday, May 17, 2016.
  • The winner will be the post with the highest bid as of 9 p.m. MST.
Be the highest bidder, and we'll produce an awesome video ad that will generate lots of business for you.
Upload the video to your YouTube channel and embed the video on your website.
Test-Drive Over $20,000 Worth of Inspection Tools
 Click here.
Test-drive over $20,000 worth of inspection tools at our upcoming InterNACHI Boulder Chapter meeting. It's free and open to everyone, and is located at InterNACHI Headquarters in Boulder, Colorado.
The inspection tools include:
New, Amazing Infrared Camera
Introducing the FLIR E5 Infrared Camera with MSX®
Now you can afford the ultimate inspection tool. Gain the competitive advantage and take care of more customers. Blow them away with dramatic MSX thermal images that clearly reveal problems -- from sources of energy loss, moisture intrusion and structural issues, to overheating electrical and mechanical equipment.
MSX® Thermal Image Enhancement
MSX adds key details from the onboard visible light camera to the entire infrared image in real time. The result: an all-in-one thermal picture with numbers, labels, and other structural features intact so you'll instantly recognize where the heat issue is.
Stucco and EIFS Walls of Defects at InterNACHI
Click here to see walls.
You're invited to check out the stucco and EIFS walls of defects at InterNACHI Headquarters in Boulder, Colorado.
We intentionally created installation defects on each stucco/EIFS wall. The walls represent the 12 most common stucco exterior covering materials.
Check out the stucco walls of defects.
Click here to watch video.
We have a short 17-minute video of inspection tips for inspecting stucco and EIFS cladding with Ron Huffman.
InterNACHI offers a course on inspecting stucco and EIFS cladding. Upon successful completion of the training course, you'll be able to properly inspect a house that has stucco or EIFS cladding.
Report Writing for Inspectors: Blueprint Summaries
    Click here.
If you missed the recent live class about report writing, we have the video recording for you.
In this video recording, our guest, Mike Crow, addresses and answers 17+ of the most important report-writing questions from beginner and veteran inspectors alike, and shows you how to most efficiently create inspection reports, while still maximizing the service you provide to your clients and customers. This isn't about specific software -- It's all about answering your report-related questions and specifically demonstrating how you can efficiently and accurately use your report to best serve all of the parties involved.
How Did Inspector John Figure Out How Much to Charge?
Here's an example of how Inspector John figured out how much to charge for his home inspection fee using a mathematical formula.
First, Inspector John calculated his billable hourly rate (assuming John has no employees yet) by using the following simple formula:
(Desired Annual Salary + Overhead + Desired Annual Profit) ÷ Annual Billable Hours = Billable Hourly Rate.
Now, add everything together (desired annual salary + annual overhead + desired annual profit) and divide that result by Inspector John's annual billable hours, which is the total number of hours he works doing inspections each year. For John, it's about 1,250 hours. The result is the hourly rate he needs to charge to cover his salary and overhead, and make a profit.
Here's an example of Inspector John figuring out his billable hourly rate. John's goal is to make $100,000 per year in salary (that's his desired annual salary as gross income, before taxes). And he figured out that his overhead is $25,000 per year. So far, John's business needs to make a total of $125,000 to pay for his salary and overhead. Now, John sets his profit margin at 20%. The question is: How much money (gross revenue) does John's business have to make in a year to reach his goal?
The equation we have is: Gross Revenue = Salary + Overhead + Profit. Entering known values, we have Gross Revenue = 100,000 + 25,000 + 20% of Gross Revenue. Adding and changing the percentage into a decimal, we have Gross Revenue = 125,000 + 0.2 x Gross Revenue, which brings us to Gross Revenue - 0.2 x Gross Revenue = 125,000. And that brings us to 0.8 x Gross Revenue = 125,000. Dividing both sides by 0.8 gives us Gross Revenue = 125,000 / 0.8 = 156,250.
Now, John's business needs to make $156,250. John plans to work one five-hour inspection job per day. Assuming 50 work weeks per year, that's 1,250 billable hours per year. So, John takes $156,250 (salary + overhead + profit) and divides that by his annual billable hours of 1,250. The result is $125 per hour.
John should be pricing his inspections at $125 per hour.
Assuming John's typical inspection takes five hours, John's home inspection service should be priced at $625. This is John's flat rate, the average fee for one inspection for a typical house in his market. John should do a home inspection for $625, give or take a little.
John figured out that $625 per inspection will cover his $100,000 salary and $25,000 overhead, and yield a 20% profit.
John has successfully set his pricing. Can you?
ADVERTISEMENTS
Elite MGA E & O Insurance
302-690-9839
[email protected]
3D Inspection System
HomeGauge home inspection software. Now with video. Click here for a free 30-day trial.
InspectIT.  Revolutionizing home inspection report writing. Learn more by clicking here.
Don't Worry About
Missing a Call Again!
We will answer the phone,
take messages, answer questions, give price quotes, schedule inspections, and text you with messages in real time.
SewerGard
Providing Professional
Home Inspectors with
quality insurance
since 1992!
The Simply Superior
Policy with competitive
pricing.
Our executive director was a home inspector for over 20 years, so we know how to "speak your language," offering you policies you can grow with.
Retrotec
Full View Digital Marketing
Infrared Certification
 Click here.
  • Lowest Cost IR Cameras in North America
  • Live Webinar or Podcast on Demand
  • $100 Off InterNACHI Renewal Fee
  • 300 Pages of Class Material
  • Free IR Classes and Podcast
  • Just Like Being at an Onsite Class
 Click here.
Inspector Services Group. InterNACHI Members get a great deal.
Interspect Software
CONCIERGE SERVICE
US Inspect
Full Websites For Home Inspectors
100-Day Inspection Coverage
( Inspector Pro Insurance Program for InterNACHI Members.  Click here for details. )
The Choice Just Makes Sense
"As far as InterNACHI is concerned, InspectorPro is the only choice for home inspector insurance."
                    -- Nick Gromicko
Certification Seals
 Members may download their certification seals from their Members-Only Account.
Print Your Certificate
 Members may download and print their Home Inspector Certificate from their Members-Only Account.
To advertise in this newsletter, contact Alicia at NW STEEL.
InterNACHI, the International Association of Certified Home Inspectors, is a federally tax-exempt, 501(c)(6) non-profit trade organization headquartered in Boulder, Colorado. InterNACHI is the world's largest organization of residential and commercial property inspectors.
MISSION
InterNACHI's mission is to operate the world's largest organization of certified residential and commercial property inspectors.
GOALS & OBJECTIVES
Goal
Provide degree and certificate programs and accredited Continuing Education to members.
  • Objective: Develop courses that combine a basic foundation of traditional education in a distance-learning format to enable members to meet their academic and professional goals.
  • Objective: Continuously build and maintain degree and certificate programs for members.
  • Objective: Obtain institutional and programmatic approval and accreditation from governmental and non-governmental regulating agencies.
Goal
Increase and strengthen the number of successful home inspection businesses in the world.
  • Objective: Offer memberships to individuals around the world.
  • Objective: Provide valuable membership benefits.
  • Objective: Develop effective business and marketing products and services for members.
  • Objective: Continue to build and enhance our education system and student services.
InterNACHI members follow a comprehensive Standards of Practice and are bound by a strict Code of Ethics. The membership takes part in the regular exchange of professional experiences and ideas to support each other. InterNACHI maintains an industry blog, Inspection Forum, and local Chapters in support of this exchange of information. InterNACHI provides its members with other means of direct and membership-wide communication to further their understanding of their particular roles in the inspection industry and how best to serve their clients. The benefits of this cross-communication enhance the members' ability to build their businesses and develop specialized ancillary services.
InterNACHI's Vision and Mission Statement
Subscribe to our newsletter.
Sincerely,
Nick Gromicko
   Join InterNACHI today at $49 per month or $499 per year.
   Visit us at
www.nachi.org/join
