Stucco & EIFS Training and Certification Course:
 How to Inspect Stucco & EIFS (16 CEs)
(for residential and light-commercial property inspectors)
Play short preview below
Play short preview above
COURSE OBJECTIVE:
Upon successful completion of the training course, the student will be able to properly inspect a building that has stucco or EIFS cladding.  With this training and certification, you can become an InterNACHI Certified Stucco/EIFS Inspector (an official InterNACHI designation).  Upon successfully completing this course, you should be able to:
  • OBSERVE wall claddings on a property and identify the common stucco systems (There are over 12 different types of stucco & EIFS common to residential and commercial properties);
  • APPLY non-invasive, visual-only inspection techniques as required by the InterNACHI Standards of Practice;
  • IDENTIFY points of concern about the stucco or EIFS installation or its condition; and
  • REPORT your findings to your clients in a concise, factual manner that is specific to the property
COURSE STANDARDS OF PRACTICE:
  • This course is to instruct property inspectors how to inspect stucco following the InterNACHI Standards of Practice.  According to the Standards, "The inspector shall inspect the siding, flashing and trim... and describe the exterior wall covering."
  • Learn how to identify the many different covering materials, recognize defects, and report on potential problems areas using the BEST non-invasive, visual-only inspection techniques.
COURSE INSTRUCTOR:
 Ronald W. Huffman, P.E., M.B.A.
 ESEC-Exteriors & Stucco Evaluation Consultants, Inc.
 http://fri-inspect.com/
 Bio of Ronald Huffman
CONTRIBUTING INSTRUCTOR:
 Dennis Rose, M.B.A.
 Technical Director for Total Wall, Inc.
 http://www.totalwall.com
 Bio of Dennis Rose
COURSE TOPICS:
COURSE INCLUDES:
  • UNLIMITED ACCESS.  You can play, stop, rewind, play again, leave and come back a week later, start where you left off.
  • THERE'S NO BUFFERING.  The video has instant fast-forward and instant reverse.  You can jump from one part of the video to the next without waiting.
  • YOU SET YOUR OWN LEARNING PACE.  You have unlimited time to learn.  You can play and replay as many times as you want.  You can watch the online video course again and again - even AFTER you take the final exam.
STUCCO WALLS:
For the course we built 12 walls covered with the most common types of stucco systems and EIFS, including manufactured stone.  Each wall has different types of stucco and several concerns and defects.  During the online course, you will have the opportunity to study hi-def, digital pictures of each wall.  Play the following video:
The stucco and EIFS are applied to interact with windows, openings, railings, flashing, electrical boxes, water pipes, dryer hoods and ledger boards. The exterior covering materials have been applied in open layers to reveal how stucco is installed and applied on different substrates.  Different drainage planes and moisture barriers are installed.
Underlying layers  and components are open for inspection, including felt paper, house wrap, OSB, plywood sheathing, hard coats, flashing, metal lath, wire and cloth, weep holes, insulation, foam, backer rod, penetrations, sealant, wall-to-roof flashing, and more.
Mr. Huffman purposely embedded defects in the installation of the materials.  Over 20 different installations with over 50 defects are installed for up-close learning.  We even spray water on the walls, and then spin the walls around and watch the moisture penetrate the interior of the wall cavity.
Promotional Video for your Real Estate Agents to See
This course includes: 8-hour training video (online, unlimited access and viewing time, 17 sections in the online course, 21 quizzes with 84 total questions (quizzes are online and graded instantly), 348-page course text book (downloaded in chapters, pdf, yours to keep), over 400 digital pictures (online, with zooming feature), 12 walls custom-built for the online course, covered with numerous types of stucco, 50-question final exam (online), instantly graded final exam (online), downloaded certificate of completion (immediately after passing final exam).  UNLIMITED ACCESS.  You can play, stop, rewind, play again, leave and come back a week later, start where you left off, THERE'S NO BUFFERING.  The video has instant fast-forward and instant reverse.  You can jump from one part of the video to the next without waiting.  YOU SET YOUR OWN LEARNING PACE.  You have unlimited time to learn.  You can play and replay as many times as you want.  You can zoom in and out on graphics and pictures.  You can watch the online video course again and again - even AFTER you take the final exam.  Entire course in full screen, high-definition!
More approved and accredited inspector education.
